rfdfirecaptain
Thread starter- Joined
- Aug 17, 2008
- 314
I have a 1993 Volvo (7.4) engine with a DP-D outdrive.
One of my trim cylinders is pouring out trim fluid around the ram and obviously it will not hold a setting. I have tried to remove the cylinder, but I cannot figure out how to remove the sleeve end where it pivots against the outdrive housing.
1. Is it possible to rebuild this cylinder while still attached to the boat? If so where can I find a wrench that will fit the 4-pin cap on the ram end to open up the cylinder? Also, where can I find a rebuild kit with the seals for this cylinder?
2. If I must replace this cylinder, how do I remove the sleeve (pivot) end from the outdrive housing? I have scoured the Internet all day for schematics to try and figure this design out. 6 hours later I still don't know how the sleeve is attached so I can figure out how to remove it.
I can send photos if necessary
Thanks!
Keith
Thanks!
Keith
