Hi Folks,
Under the category of "it's always something":
Earlier this Spring, I had a trim cylinder leak on my 2005 Johnson 90hp with the common Showa model trim/tilt. I replaced both trim cap assemblies with new aftermarket replacements that can be found on eBay, after reading positive reviews and contacting the seller, who assured me the aftermarket parts are high quality and they use them in their own business, which is rebuilding trim/tilt units. They had these parts, including all of the o-rings/seals, manufactured for their use. So they now also sell the parts on eBay and Amazon.
Anyway, I installed the caps back in the first week of June. Everything went smoothly and I'm sure I installed them correctly, including torquing to spec. I also replaced both trim rods with used, but in excellent condition, rods from a freshwater motor. My original trim rods were getting pretty corroded and I didn't want to risk re-using them. The "new" ones have no corrosion, pitting or nicks at all.
This weekend I noticed I have a small leak out of both caps at the wiper seal where the rods push through. It's not leaking when not actuated - i.e. - it "stops" leaking when sitting for a bit. I'm getting a couple of drops leaking immediately when actuated down then up. Of course as the motor is used in real time, it gets actuated frequently and hence more leaking I am sure.
Am I correct in that the inner o-ring in the cap should not be allowing fluid past? The wiper seal on the outside is there to help prevent debris/water from ingress into the cylinder, and not stop fluid leaking out? If so, I'm guessing the inner o-ring seals are not sealing correctly against the trim rods.
Finally, has anyone had this experience? I'm not interested in faulting the seller or his/her business - aftermarket parts are buyer beware. I'm kicking myself for not going with OEM in the first place to save a few bucks, but that's water under the bridge now. For those with experience using aftermarket trim/tilt seals vs. OEM, will OEM parts likely make the difference for me? I'm not sure what else I can do at this point other than give OEM a shot and put my tail between my legs for wasting some dough.
Thoughts?
Many Thanks
Thoughts?
Many Thanks
