Trim fluid check and fill
Estoman
I have a 1990 90hp Evinrude, I have been told that the trim does not sound right when its engaged, it was suggested that I check the fluid level. Great! how and where?
Thanks Estoman
angus63
Re: Trim fluid check and fill
Remove cap from resevoir next to trim motor. Add trim hydraulic fluid up to neck. Cycle motor fully up and down 3-4 times. Check level and add up to neck if required.
Good luck
HighTrim
Only thing that I would add would be to make sure the trim is in the full up or out position before filling the resevoir.
