trim function
Jcris
I have a commander 3000 control on my alpha 1 gen 2 that doesn't seem to work correctly. There's a small rocker switch on the handle that will lower the drive but not raise it. There is an additional switch on the bow that will raise and lower the drive without issue. Does that seem right? I inspected the trim and limit switches on the drive and found both had some exposed wire where the insulation had broken away. From age I guess. Is it time to replace these switches?
Ayuh,.... That switch Should do both, raise, 'n lower the drive,...
My guess is the wirin' is bad at the limit switch, 'n/ or at the pump,....
