Hi All,
Boat is a 1995 Lund Tyee with a 4.3L H.O. and a Volvo DP-C out drive. My trim gage reads full up all the time whether the ignition is on or off, and if the drive is up or down or anywhere in between. The gage maybe moves about 1 millimeter. Is this usually a gage issue if they don't move or could it be the sender? I checked the manual and it seems like the only way to check the sender is with what looks like a special tool, not a volt/ohm meter.
The trim stop relay cuts out at max trim, and the max tilt relay (could be the same) cuts out at max trim up. Just the gage doesn't work.
Any help would be appreciated, thanks in advance.
