Ifishmuskie2
Thread starter- Joined
- Oct 5, 2025
- 148
I worked at the spaghetti factory (wiring) all day. I got most of it done.
Trim gauge is not working. The trim gauge might not be original. there is no wire for the light and I can tell it never had a wire hooked to it. the hole is cut out different from the rest.
Gauge is out of boat and I get 116 ohms. Is that ok?
Two wires are together a white and black stripe that was hooked to the signal post And a tan wire that was not hooked up to anything.
What reading should I get from the signal wire?
Thank you.
Thank you.
