Trim hose from manifold to inside
Jakem
Alright...new problem lol. I blew one hose inside the boat and removed the connection on outdrive. I managed to get very frustrated as I was doing this alone and I have hooked the 2 trim hoses up backwards...old alpha..mc-1 I believe. Is this going to cause any issues
04fxdwgi25
As long as the correct port on the pump is connected to the correct external hose, it will work. But the external hoses will interfere with each other is not positioned correctly.
Personally, I would correct the internal hose connections on the manifold. Not knowing which pump you have, you may be able to correct by swapping hoses at the pump.
Jakem
Ya I'm going to drop external connector and change there it isn't working right for sure
