Trim hose to pump
jlaeder
Hi from Michigan new member to this group. I bought a 1990 cheetah with a 4.3 mercruiser a few weeks ago and it needed a new trim pump. The previous owner (coworker) took the pump off and took it to a marina to see if they could get one (it's still there). So I bought a whole new one, went to put it in and the fittings on the pump wont work with my hoses and I cant find anything online about the fittings or the hose that's in the boat. Am I gonna need to change the hoses or can I just get the correct fittings? Thanks for your help 20210417_171007.jpg
Ayuh,.... Welcome Aboard,..... You just need the right fittings,....
I believe yer hoses are the older style,....
Bt Doctur
older ot not, I`v never seen that type on a merc pump from any year
might need to replace the trim hoses with oem
jlaeder
I thought they were OEM but cant even find the hoses or the type of end online.
I'm saying the lines that are on there now. This was the original pump with those hoses.
Ayuh,...... Do you still have those hose to pump adapters,..??
If so, just swap 'em onto the new pump,.....
Scott06
My thoughts as well or find a hydraulic or forklift repair shop can probably set you up with the right fittings or put new fittings on your hoses.
jlaeder
That's the plan now, waiting for the coworker I bought it from to get it from the boat repair shop he dropped it off at last year. Should have it tomorrow. Thanks for your input. Cant wait to get it in the water when the weather cooperates, its snowing here right now 🤦‍♂️
achris
More fish than mountain goat
Yeah no, those are not Merc fittings. Merc have been using the same fittings on the trim pumps since before 1970 (the ones in BtDoc's picture). Those you have are locally made. I suspect the old pump will have either an adapter or someone has replaced the original receptacles in the pump...
jlaeder
Thanks for all your information, I got the old trim pump today and the fittings they had in it were npt going into the pump. I'm assuming they used whatever they could to make it work. I ordered new hoses today to make it right. I appreciate all the input.
