Trim hot wire question
bear_69cuda
I need to raise my lower unit so I can get my boat outside for a bath, post fiberglassing deck. I have removed all trim/throttle controls. I'm curious if I connect the 12v power for trim motor to battery, and connect the R-PU (red-purple = trim switch power) and the BL-W (blue-white = Trailer-up) wires, will this work for raising the trim? Or do I need to connect the switch on the throttle back up? Now it's attached to the side panel currently out of the boat.
Thanks in advance.
Re: Trim hot wire question
Ayuh,...
If you put Power to the trim motor,...
Yes it can be jumpered to raise thedrive, without rewiring the whole thing....
bear_69cuda
Worked perfect!
Thanks again dude!
Now time for fliberglass dust clean-up hell.......
