Trim Limit Switch, Internal Wiring to Pump unit...?
mega6490
Bought a boat that had the trim limit switch internally disconnected from the pump. There doesn't seem to be a typical harness to connect it too. My question is where do I splice in the two wires to make the system work. Let me know if you need more information.
For an Alpha one, Gen One.
Thanks,
Zach
achris
More fish than mountain goat
Re: Trim Limit Switch, Internal Wiring to Pump unit...?
Does this help?
attachment.php
mega6490
It does, however looking at the pump assembly I'm still not sure where to tie the switch in. The sending switch is hooked up fine to the gauge, however I have the two other wires just sitting by the pump, and no harness where it would typically plug in. Anyone tie their wires in manually (without harness type hookup)?
Thanks!
