Trim moldings
drewpster
I know I have posted this question before, I was hoping someone had some more suggestions. I need some (actually allot) of trim pieces to replace the old corroded aluminum trims original on my boat. The original trim looks like 3/4 cove molding only in aluminum. I have looked at Taco's website and I am not finding anything I want. What I really want is some simple 1/2-3/4 UV stable plastic molding I can use in corners.
I considered using wood, but I would need a hardwood and I bet the cost would be considerable. Also that is allot of little molding to paint.
Any thoughts?
drewpster
Re: Trim moldings
Rub rail is not the animal I am talking about. The trim moulding I need is used to finish off inside corners, cover seams ect.
Bob_VT
Re: Trim moldings
Some building supply stores have plastic molding but completely unknown about the uv properties.
sdunt
Re: Trim moldings
There are exterior vinyl mouldings available at Home building centers. They are generally considered garage door mouldings and I have found small corner mouldings at my Menards store.
