mt_bulldawg
Thread starter- Joined
- Jun 18, 2008
- 37
I have an '84 SeaRay with 3.8 and OMC - I think it's the 800 stinger? My understanding is the trim motor on this is also the same motor that does the "trailer up" tilt? Here's what my problem is - I can't get the motor to "trim down"...it appears to be all the way up - both solenoids for trim are working - you can hear and feel them...so power at trim switch is good to solenoids...but it will not tilt the whole motor from front to back bringing lower unit closer to parallel with transom...it just "whirrs". My seloc manual says the whole trim pump and motor is a sealed unit - nothing has to be done...I see no leaks at trim pump, but I'm wondering how to check fluid level, or is there something else I'm missing? I'm plowing more lake then I'd like to be plowing out there....
Thanks in advance.
P.S....just to be sure, I did change out both those solenoids....didn't make any difference.
Thanks in advance.
