trim O-ring replacement?????
dungY
I am having problems with my trim.<br />the battery is fully charged and solenoids work fine... as i press the up trim i hear the motor pump but nothing moves..... press the down trim and the same thing...the two tabs are are out and the hydraulic stuck in the down positiion....<br />i noticed a leak in hydraulic fluid coming from one of the pins. <br />How do i change the O-rings??<br />and what is needed and where can i get these parts.<br />what tool is needed to remove that part.. in the picture with the four holes that surround the pin??<br /><br /> http://www.geocities.com/evangelion_21/boat/boat6.jpg <br /><br />any help would be much appreciated for no work can be done until the trim will allow to raise the motor back up<br /><br />thanks in advance,<br />dungY
Terry H
Re: trim O-ring replacement?????
don't know what motor you have but any J/E dealer should have the seals and o-rings. You also might check the fluid...if it's leaking you might be low and that could be the reason for non-operation...just a thought :)
Richok
dungY don't know what you have engine wise,but I had a similar instance this summer and had a spring broke under the pump. Its about the size of an ink pen spring. My 2 cent worth.
