I am having problems with my trim.<br />the battery is fully charged and solenoids work fine... as i press the up trim i hear the motor pump but nothing moves..... press the down trim and the same thing...the two tabs are are out and the hydraulic stuck in the down positiion....<br />i noticed a leak in hydraulic fluid coming from one of the pins. <br />How do i change the O-rings??<br />and what is needed and where can i get these parts.<br />what tool is needed to remove that part.. in the picture with the four holes that surround the pin??<br /><br /> http://www.geocities.com/evangelion_21/boat/boat6.jpg <br /><br />any help would be much appreciated for no work can be done until the trim will allow to raise the motor back up<br /><br />thanks in advance,<br />dungY
