Trim position sensor or ??
sschefer
Can someone tell me how Merc/Mariner trim/tilt gauges get their signals. Is it from the trim motor or is there a sensor (potentiometer) that's attached to the engine mount bracket? I've been trying to find something in the parts lists for any year (Mines the 91 Mariner 100hp serial # 09655784), but haven't seen what I think I'm looking for. If the motor is a stepper motor on the new models then I'm guessing that's were the signal comes from.
I have a positon sensor for my Hydraulic Jack Plate and it works with a simple pot and rack/pinion gear setup. I'm thinking that if I can't figure it out I'd just order one of those and rig it up.
This is just one of those nice to have things and not a critical must have or I won't go fishing items like beer.
Don S
Re: Trim position sensor or ??
Tilt the motor all the way up, then look on the port side where the pin thru the tilt cylinder is located.
attachment.php
sschefer
Thank you, now that I know where it's supposed to be I can try and find one that I can make fit my Mariner. PERFECT !!!!
sschefer
The motor is on a stand so I hooked the battery up and tilted the engine. There she was, the mounting point for the sender but no sender.
I finally found the sender at saveonboating.com, (57.91 after shipping, no tax). I didn't find the gauge there so I got if from Overton's. I also found the 30lb Water Pressure kit I've been looking for at Overtons. West Marine had a merc tilt/trim gauge on closeout sale but who know's if it was the right one or not and I hate doing returns. Looks like I'm all set!
As a side note, the different versions of the sender require the correct gauge. If you know a little electronic's you can make the newer gauges work but I wanted to make mine as simple as possible and I wanted a Teleflex gauge to match the rest of my gauges.
