Craig Winnerman
Thread starter- Joined
- Mar 22, 2009
- 16
I just replaced my digital gauges with Teleflex Analog gauges. All is fine except for the trim will not go up. I did get a pre 2001 Yamaha trim gauge made for 3 wire. The trim will go down from throttle button, but not up. At the motor trim switch the engine will go down as well and you can hear the solonoid click when pressing the up button at the engine. I used the pink wire for sending at the gauge and gounded gauge with the black wire in same harness which I think is an engine ground. Did not use orange wire and used gray wire for temp sendor which I added the temp sender on the engine and used the gray/black wire from the original sender on one side of the cylinder bank. Dark green wire to Tach. White wire to fuel. All gauges grounded to ignition ground except for the trim which is grounded to engine. The fuesed red wire from ignition is not used as well only the yellow hot ignition wire is used on all gauges.
1997 S150TXRW on a Century 2201 bayboat
