trim problem
teamdrum
1989 four winns 210. 5.7 mercruiser. had some engine work and when the boat came back the trim was not working. when i hit the switch i hear a click but no movement in the outdrive, no whinning of the trim motor.
cablerider
Re: trim problem
I've got the same exact situation on my '88 Liberator 201. I'm looking into it now, but if you find out something first, lemme know. As soon as I know something, I'll post it.
blue250r
Re: trim problem
Same thing happened to me, thought it was corroded connections on relay/fuse box (mounted on the trim hydraulics)... tapping the box actually got it going, assuming the relays are getting stuck, might open the sealed unit to fix
cablerider
Re: trim problem
OK. I went through all connections, etc. Long story short......bad pump. I replaced it and everything is fine now. If yours only clicks going up AND down (no pump whining), that could be your issue as well.
