Trim problems
Richard1991
I have a 2007 150 evinrude etec that the trim stop tab ground wire is getting hot and the trim stopped working i can here the relay clicking but nothing else works was wondering if anyone knew if it might be the trim motor or the trim stop tab
Crosbyman
are you referring to the trim upper limit switch that keeps the OB from raising further up ?
that switch is simply a normally closed switch andallows the T&T to rise
it mechanically opens the UP circuit feeding the UP relay since it is wired in series . AT the upper limit this stops relay provided high amp. current to the T&T motor up movement
trim switch is fed on B+ fused at 10 amps . wires getting hot would indicate the presence of current flow coming from the front or cowl "up trim switch"
i'll post the wire diagram in a minute
meantime check all connections ...check switches. clean contact surfaces in connectors.
Crosbyman
see diag.
Richard. btw your best place for ETEC problem solving (no offense) is the ETEC OWNERS BOARD forum where only ETECs are discussed. also has an excellent search utility
  • ETEC 150 wire diag 2007.pdf
saltchuckmatt
Had that same issue (been awhile) and the Cro's helped me thru that.
Another common prob is the tilt mechanism will make a screech type noise going down sounding like you need a new or need to clean an internal bushing. There is an easy fix for this common problem.
Let us know if this is an issue.
Fun fact, the Gen one 150 is a 6 cyl. And the Gen two is a 3 cylinder.
