OK guys here we go again... 1990 Cobalt with mercruiser 454 mag 7.4l and bravo 3 OD. I just had the outdrive replaced brand new with new trim sender and limit switches installed. Today I adjusted them and everything is working fine as far as the trim gauge and trim limit. The problem I am still having is this... The trim and tilt works fine at the dock and at low speeds. As soon as I take off or while i'm at high speeds the trim DOES NOT WORK!. Its driving me nuts. I get back to the dock and it works fine again. It seems as if the pressure isn't strong enough to lift the drive while i'm underway. Its definitely trying cause I see the battery gauge draining power when i push the trim buttons. Is there a test I can run to troubleshoot this? Has anyone experienced this at all? How do I know if its the pump motor, solenoid, valves? Is it possible that the grey and black hydraulic hoses to the trim pump got reversed somewhere? As of now the gray is on the right and the black is on the left but I dunno if the mechanic reversed them on the drive possibly or if this is even a possible solution??? Any help would be greatly appreciated. Im going nuts with this one..
