trim pump help
Vision91
I need some help finding a new trim pump to replace the factory pump i have..ive attached a pic of the one i have now, the motor ziezed up in it wont turn or anything i replaced the brushes about 6 mths ago and it worked for a while but now nothing..i have been looking at some new units on here but not sure which one to get or if it comes with everything to install it..please help with this thanks
Chris1956
Re: trim pump help
That motor used to be avail aftermarket. It came as a motor/reservoir combo, however, there was more than one, and they looked almost identical, except one would not work, as the armature was too short. I would look them up on the web, and find one local to you. Take the bottom plate (pump and control valve) off your resevoir and take the motor/reservoir down and match it up.
It might be easier to see if a starter shop will fix your old one up.
Vision91
Re: trim pump help
yea thats the problem im having is trying to find a motor with the same size armature as the one in the pic...the problem i have is most shops around my area dont work on them or doesnt want anything to do with it since it wont bring them that much money. so im looking at one on here..heres the link Mariner, Mercury Marine, Mercruiser Inboard Replacement Power Tilt and Trim Motor 6217 - Arco - Parts Finder - iboats what im looking at im just not sure what parts i need to buy or if the one i have i can use in it
merc850
Re: trim pump help
trim-pump-exploded.jpgIf it doesn't work anyway why not take it apart and find out why?
I got one last summer that was seized from water intrusion, took it apart and cleaned it and now it works.
Vision91
Re: trim pump help
already did that and from what im getting, is it magnetic locking itself as soon as power is supplied to it. all connections are correct so i guess its already ran its last leg so thats y im getting a new one but need to know which one to get
Chris1956
Re: trim pump help
well, That pump says it is the correct one. I presume your motor is 1970-1977 IL4/6? That one should mate with the pump and reservoir base unit you have. Best of luck....
Vision91
Re: trim pump help
ok thats what i was lookin for appreciate the help on this and its the IL/6 1150
