Trim Pump issues
gshldon
Hello,
I am having an issue and need some advise on where to go,(besides crazy).
My old trim pump died last year, replaced it, but the issue is I replaced it with one that had 2 relays/selinoids and converted that to just the 1 silenoid, pump works, but when I got to start the boat the silenoid just clicks,
and I know the battery is good, it was just taken off the charger and I even took one out of my vehicle.
to make things clear, the silenoid that is clicking is on the trim pump itself, and not the starter silenoid...
I am thinking the wiring may have gotten messed up, any ideas on where to find a good wire diagram to go from 2 silenoids to1?
any ideas would be certainly welcome.
Thanks
Don S
Re: Trim Pump issues
You need 2 solenoids not one, the wiring going to the helm on a 2 solenoid system is smaller than the wiring on the single system.
gshldon
Thanks Don,
The original pump that was in there only had 1 solenoid, maybe that is because there is no 3 button switch at the helm? all it is, is a toggle up and toggle down switch, and no tilt or trim in the handle either.
does that make sense?
Don S
Ok, you have a single toggle switch for up and down without a trim limit switch or a gauge is that correct?
gshldon
Yes and no, lol....there is a gauge and there are trim limit with a single toggle switch, the gauge is not functioning as the wires on the trim switches is all corroded and broken.
Don S
Are you using the trim limit, or want to? You can't use it with a single toggle switch. you have to have another switch to bypass the trim limit so you can put the drive up to trailer position.
gshldon
at this stage, I am not going to be pulling the whole drive off just to replace the switches, so no, I have been using the boat the way it is for the last 5 yrs and just want to get it back out, and this little issue is holding me up.
So I am just gonna stay with the toggle switch for now, and when I do an overhaul of it this fall and winter, I will replace everything then and get a side mount control with tilt and trim in the handle, at which point I will wire up for that.
gshldon
ok, so i have to have 2 solenoids? just want to make sure as the original pump only had 1 solenoid.
gshldon
since it only has 1 solenoid now, would that cause the down to go really slow? up is really fast.
Don S
Yes, Low amperage through the small wiring, that is why they stopped using the single solenoid system 30+ years ago, and why they use slave solenoids.
Hook up a second solenoid as shown in the wiring diagram and it will work.
gshldon
Ok great, Don, thank you so much for the information, I truly appreciate the expert advice and help..
achris
More fish than mountain goat
The harness wiring for both 1 and 2 solenoid set-ups is the same. Just unplug the harness, change the pumps and plug the harness back in... No other changes need be done... If it was just the pump motor, same thing. Pump has 3 wires. Black to ground and blue to UP solenoid. The green is the different one. In a 1 solenoid system it goes to the back of the harness connector, in the 2 solenoid system it goes to the DOWN solenoid. I really don't see where the problem is.
Chris....
salfred31
This is probably a stupid question but a friend of mine gave me a new trim tilt pump/motor. Problem is when I went to hook it up one of the hydraulic lines, the screw on the end is to small to screw into the pump. I have a pre alpha stern drive. Does that mean the trim tilt is not compatible with my boat. I have an old Glastron-mercruiser 898 305. Thanks
Don S
You need to start a new thread of your own salfred31, include what your new pump is as well as your old one.
achris
Best start your own thread and not hijack this one....
