Trim pump leak
Yeah it has two cylinders to lift the motor.
Ayuh,.... All the I/Os do,.... The trim pumps for I/Os also only have 2 hyd. lines,...
If you've got 4 ports on the pump, it's an older Outboard trim pump,....
sharkin95
Plenty of these on E-bay under $150.00 used these sell new for $375.00 and up
Derekc294
Sharkin my issue is I can't figure out what would be a direct replacement for the model I current have.
sharkin95
the direct replacement is Mercruiser oem #45060A1or A7 or A9 there is one on e-bay now......
Derekc294
No luck locating the pump leak so I will be adding thread sealant to the 4 lines and putting it all back together. I am planning on monitoring the pump for leaks once its back together with a plastic catch pan under it to avoid the oil from going into the bilge area. I talked with a local shop and they advised this course of action before disassembling anything.
I also rewired the entire boat finally and installed new bilge and live-well pumps. The previous owner used garden hose from the pump to the livewell and from the bilge to the outtake on the side of the boat. Unreal what some people will rig up.
