Tharding
Thread starter- Joined
- May 14, 2021
- 11
Greetings!
I'm new here so thank you all for your patience!
I have a 1997 Glastron SE 195 w/Penta 4.3 GL and SX Outdrive. Boat runs great and I am very happy. Recently, I have noticed that the tilt/trim pump is leaking hydraulic fluid. The outdrive is still actuating up and down and there is no uncommanded rise and fall of the drive, BUT I am concerned that the tilt/trim pump is on its last legs. It is the old OMC style pump with Penta part number 3855745 (see pic). My questions: 1) Should I just deal with the slow leak this season and worry about repairing this winter? 2) Because this trim pump is no longer manufactured (I believe), what is the replacement pump I can use for this application? I have researched the entirety of the internet and have found much conflicting info. 3) Lastly, should I decide to replace the pump, where can I find the procedure to do so? I presume that I will need to bleed the lines?
Thank you to anyone who is able to assist!
