Trim Pump Question
jorgeoliva
My trim pump pump when you press the button on the shifter it click on the pump until the trim pump activates where can I find the relay for this the pump is a 2000 its a SAE J1171 Marine or can they be fixed
Alumarine
The clicking you hear is the relay, or relays if there's two.
Check and clean your connections at the trim pump and the leads from the pump to the battery.
