trevtt600
Thread starter- Joined
- May 17, 2009
- 80
Sorry for the second post, but figured i should separate this question with last question.
Starboard trim pump (Newer Olidyne version with plastic reservoir) with work great in trim up or out position. Try to get drive down or in, and it will not go down, but the pump is making a high pitch squealing noise. If i switch the hydraulic lines at the trim pump, i can get the drive to go down just fine, but will not come back up. If I would switch hydraulic lines back to normal, drive will trim up, but not down... What does it mean when the trim pump will works this way? Is the down valve stuck or plugged internally in the trim pump? If so, can I fix the valve, or have to replace the whole unit?
Once again, this is on a Wellcraft Monte Carlo with twin 4.3L and alpha one gen one drives.
