Trim Q again
oldsub86
1973 OMC Stringer and 3.0 140 Hp engine with trim setup.
Goes down when I push the switch down but only clicks when I push the switch up.
On the engine under the manifolds, are 4 solenoids. I am assuming 2 relate to the tilt and 2 to the trim.
Anyone know off hand which are for the trim and which is for up vs down?
I could trace it out but if someone knows, it is faster than DIY.
Randy
Boomyal
Re: Trim Q again
I'm sure it would be easy enough to trace the wires. Also check all your connections for being clean. A clicking solenoid is a prime indicator of a bad connection.
