Trim relays
gshultz
I have a 1991 stratos 264 with a 120 Johnson. Does anyone know the location of the trim relays? Thanks
dwco5051
Check on the center of the back of the motor for a black box about 5 x 3" or so. Two screws take the cover off and the relays or in the box if it is the same as my old 1990.
gshultz
Sweet thanks I'll check it out tomorrow if it doesn't snow here in Gatlinburg.
gshultz
I couldn't wait till tomorrow found the box but mine is on the side of the motor. I "pecked" on the relay and my trim started working. Have new relays on the way and am going to rebuild the trim because moisture is inside. You couldn't tell me where the tell-tale or pee tube goes on the motor. The tube got caught in the cowl latch and pulled it loose. Thanks
