Trim sender adjustment
jorgeoliva
well finally working on removing the bell housing. had to heat the hinge pins to remove, notice my trim sender both side cables are toast so going to replace them is there instruction on how to set them when I build everything back up again
Ayuh,.... In the manuals in the stickies,....
Alumarine
In the replacement kit there will be instructions for adjusting them.
It's the easiest part of the job.
Good time to check out your bellows, shift cable, ujoints and gimbal bearing.
jorgeoliva
Hi marc replacing everything back there my bearing are good no play no noise rolls very smoth
