Xesvuli420
- Joined
- Sep 20, 2009
- 144
Could someone please look at this...
http://forums.iboats.com/showthread.php?t=355378
Thanks so much
Thanks so much
Its a a sender...a resistive device. There are no capacitors or active components. Its also not a transponder!!!Looks to me like the meter is charging a circuit or capacitor in the transponder and it's powering up slightly consuming more power the circuit discharges and the numbers your seeing are is the impedance of the circuit as it charges and discharges.
Whats the point? I don't think the transducer is resistive, it's an electronic component.
I don't think you can even call a transducer a transponder.Sorry -- My eyes read transducer, I'm thinking sonar not sender....
Maybe you aren't measuring this correctly. How many wires does this sender have? If only 2, you just measure the resistance across the two wires with these 2 wires not connected to anything....no connections to ground. If there are 3 measuring across 2 will get a resistance that does not change and across any of the other combos, you will get a varying resistance. Basically, the sender is a potentiometer with one of the wires connected to the wiper.I had the multimeter connected to the end of the brown and white sender wire from the sending unit, and to a ground. The Sender wire was completely unhooked from everything but the alligator clip to the meter.
All posts are worth exactly what the reader paid.
Sue me I was close...
Transducer
A transducer is a vibratory electro-mechanical device capable of transforming electrical energy into mechanical or acoustic energy or the opposite. The transducer is able to use both effects of piezo-electricity (direct effect or the inverse effect, comparable both to a microphone and a loud-speaker in aerial acoustics). The two main characteristics are :
- Its transmission sensitivity (in dB reference μPa/volt).
- Its reception sensitivity (in dB reference volt/μPa).
One can optimise all their characteristics by producing groups of sensors. Thus it is possible to produce arrays of forms and dimensions designed specifically for their particular applications.
Note/A transducer, to optimise its performance, is most often of a dimension that allows it to function close to its frequency of resonance, rather than in respect to bandwidth.
A transducer can thus be used for transmission as well as for reception.
Transponder
It is an acoustic receiver/transmitter which, on reception of an acoustic interrogation signal transmitted wireless, responds on another frequency.
The acoustic transponder is an apparatus built to be installed aboard a mobile underwater vehicle of a ROV or AUV type or on a fixed underwater installation.
Really? You can spot a link to a video, but you can't make out the words before it? Maybe if I put it in a "Qoute Box", you might notice it... Then again, prob not! But here goes anyways...Whats the problem? The gauge doesn't work? You point us at a video with no explanation and expect an accurate answer.
So really Mr. Rich, what part of that is not an...The OP said:BOAT:
1987 Dixie Bandit
OMC/Cobra 3.0L I/O
This is a video of a resistance test on the Trim Sender Output wire at the gauge, to ground. I also tested at the Sending unit itself, but forgot to record the video. It doesn't matter though cause the readings were the same. It looks to jumpy to me, BUT it does seem to kinda work. HOWEVER when the gauge is hooked up, it either reads FULL TILT, or at the number "2", depending on its mood that day lol =o). What do you professionals think? Does this unit look to be bad? Thanks ahead of time for your help.
http://www.youtube.com/watch?v=QlWr89oc210
???explanation
