Trim Sender Location-1996 Force 120HP
kinggabbo
My trim gauge is not working on my 96 Force 120HP motor. I was wondering where the trim sender was located on it. I also am not sure what it looks like. I have a factor and a clymer manual for it, but neither one has a good picture of it. Thanks for the help.
kandil
Re: Trim Sender Location-1996 Force 120HP
It should be near the tilt bracket if you post a photo of your tilt and trim with the motor tilted up some one well tell you where it is
kandil
I am not sure but I think it is attached to the white cable!!
kinggabbo
OK thanks. I will check and see what that cable is attached to when I get home.
kinggabbo
I checked where that white wire goes. It looks like it runs into a cylindrical shaped between the motor and the mounting bracket. It runs into there with several other wires.
kandil
Hi man check this out I think it will look like this one I could not find any thing in the shop manual so it must be an add on :confused:
itzmepete
Did you ever find where that trim sender on your Force 120 was? I want to install one as my boat has a trim gauge but don't know where its supposed to go if it even is installed. Any help would be appriciated.
kinggabbo
Yes I think I found it. If you are facing the prop, it is on the right side of the motor and it kinda "sits" on top of the top anchor pin for the trim unit, the part that goes through the top of the trim ram. I never did replace it however.
itzmepete
Yes, found it on my 99 120 as well. Found the slot cut and the two mounting holes. Got a new trim sender for $17 on ebay including shipping! Mounted it, wired it in to the guage and works like a champ. Was the same sender as pictured above.
GMV
Hi, could you please tell me the ref. number for these senders or the vendors name on ebay, i also need to replace it on my Force 120 (1996) ?
thanks, GMV
nickevo
im sorry i don't understand where your talking about?
Im trying to find it on mine and i can't.
is it inside the motor cowling?
My trim ram is on the left side from facing the back of the boat with the prop towards you?
please help this is driving me BONKERS!!
cheers Guys and gals
jerryjerry05
This thread is over a year old.Post your own questions on a new thread.
Need serial#s and model#s and any info you have.
Most times it's on the transom assy.If it's there??? J
