Re: trim sender wireing
Kinda missed is the correct answer! Here is how i operate my trim.
Hit the up button (raises the trim)
I hit the meddle and bottom button + addition fuse switch = lowers my trim. It takes two hands to complete the lowering.
Now you know why im so confused lol.
EDIT:
I called the dealer who hot wired it for me.
He said the TP which is on the right side, those two wires need to clip in to the two wires that are located towards the rear of my boat that are not connected to anything currently.
I will try that but i am confident that it will not fix my problem. Is there a way i can test my TP sending switch?
If your trim up (the middle button) works, someone has already bypassed the trim limit switch.
In the stern there should still be a connector with two blue/white wires coming out of it. the way you normally bypass the trim limit is to jumper between the p/w wire and the b/w connector. Sounds like it is kinda messed up.![]()
EDIT:
