Trim sender
GasCan II
Hello all;
Here's my question; The trim sender on my 1997 Mercruiser Bravo II drive is not working, the gauge is pegged all the way up and does not move when I move the drive up and down .Everything worked fine before winter lay up. Is there a way to test the sender and or gauge to see what the problem is ?
Thanks.
Hello all;
Thanks.
Loosen the screws holding the sender on the starboard side of the gimbal. You could even remove the sender. Turn key to ON and rotate the sender to see if you get movement. Move then likely you will need to replace it, they go bad often.
GasCan II
Thanks AllDodge;
Can it be replaced with out taking the gimble apart ?
Thanks again.
Well, a friend of mine replaced his by cutting the wires and splicing the new one in with heat shrink connectors with heat shrink around both of them. Still working. There's also a kit to go around the gimbal install. It involves drilling a hole for a brass fitting that the wires run through.
Bayou Dave
I changed my trim sender and trim limit switches on my Alpha One Gen One 2 months ago. Just cut the wires, spliced them to the new ones, heat shrinked them and then put liquid tape over them. So far no problems. Others here will say that it is only a temporary fix. Guess I will find out as time goes by.
GasCan II
Thanks guys, I think I will cut wires and seal good and see how that works !
GasCan II
Hello Guys;
Well I got the new trim limit and sender but , before changing them out I cleaned up the sender and put it back on and it works fine . So I dogged the bullet this time .When I change out the bellows I will put on the new switches.
Just wanted to thank you guys for the help !
achris
More fish than mountain goat
One problem with cutting the wires is that often the wires themselves have the first stages of corrosion and don't last long. Another is that cutting and soldering causes a short length of 'stiff' wire that can't bend properly. The first section of flexible after the join becomes a weak point, and will be the first place the wire will break (remember theses wires move around quite a bit when you are steering and trimming the drive).
