Re: trim slow going up and down
Could be the pump weak, or the trim cylinders corroding and causing the slowdown.
Without the proper guage manifold, it's going to be hard to tell. But you could pull the trim cylinders off and operate them by hand. After you get the oil out, they should move easily. If they don't or you can't move them by hand, well...... you found your problem.
