I tested the bow switch & i'm getting some current, but just barely, nowhere near what it should be. I can't get to the wiring easily to test the switch on the control. The only wires I can see is red/white, blue/white, green/white coming from both. I've read that the blue/white & green/white are the up/down or vice versa, so I'm guessing the red/white is for (+) coming from somewhere.
My question is where does the red/white wires go to draw the power for both switches? Directly to the battery, off the fuse panel, off the ignition switch, etc. A wiring diagram sure would help.
I have my control manual, but it shows a red wire going to the ignition switch, which i'm either blind or there isn't one.
Oh by the way if it helps:
1995 Starcraft Superfisherman 17'
1995 Mercury 115hp 4cyl 2stroke
Quicksilver Commander 3000 control
