Trim switch dead in bow & on control - works on cowl
INHUNTER
I tested the bow switch & i'm getting some current, but just barely, nowhere near what it should be. I can't get to the wiring easily to test the switch on the control. The only wires I can see is red/white, blue/white, green/white coming from both. I've read that the blue/white & green/white are the up/down or vice versa, so I'm guessing the red/white is for (+) coming from somewhere.
My question is where does the red/white wires go to draw the power for both switches? Directly to the battery, off the fuse panel, off the ignition switch, etc. A wiring diagram sure would help.
I have my control manual, but it shows a red wire going to the ignition switch, which i'm either blind or there isn't one.
Oh by the way if it helps:
1995 Starcraft Superfisherman 17'
1995 Mercury 115hp 4cyl 2stroke
Quicksilver Commander 3000 control
Barnacle_Bill
Re: Trim switch dead in bow & on control - works on cowl
Those switches on the bow get a lot of abuse just from the location they are in. Try shorting the + to the other wires and see if it works. it may be as simple as a bad switch. Where were you connecting your ground lead when checking voltages?
INHUNTER
I was putting the ground lead to the other wire, green/white or blue/white. I don't think its a switch problem as the one on the throttle control quit working the exact same time.
Barnacle_Bill
The ground lead from the meter has to be connected to battery ground to read voltage.
INHUNTER
Gotcha, I figured I was doing that wrong. I'm learning this stuff as I go. I'll check it again. Do you know where the red/white wires from the trim switches on the throttle lever & bow switch go to in case I still don't have power getting to the switches?
Thanks
