Re: Trim tab usage
I want a fuel flow meter as well, but the fact is it will take a long time to pay it back with savings if that's your plan. I have studied data for years and almost every single I/O combo out there, especially 18 - 25 ft, has it's best planing speed fuel efficiency at 3000 - 3500 RPM, and between 25 and 35 MPH. Be really careful to draw a conclusion that these engines are most fuel efficient at that RPM, they aren't!!! The combination of these engines, drives, hulls, gearing, propellers, speed and hydrodynamics makes them most fuel efficient at that RPM, and as some have noted, even more efficient at idle where gasoline engines (Otto cycle) are actually at their worst efficiency as an engine alone.
Maybe something to help understand this is that in a wheeled vehicle, most gasoline engines are spec'd to cruise between 1500 and 2000 RPM. Just so happens with their combination of load, speed, aerodynamics, tire deflection, gearing, operating flexibility etc. etc, etc. that that's where it falls. Annnnnd, if you were setting up a fixed speed and load application for an Otto cycle engine (4cycle, spark ignition and a throttle), and you didn't care about engine life, or potential damage etc. it would probably be most fuel efficient at peak torque RPM and wide open throttle.
