Trim Tab Use
JEBar
Re: Trim Tab Use
If you are still installing a trolling motor I assume you've figured out any conflicts between the tabs and that motor? Can you bow-mount an electric?
she already has a bow mounted electric trolling motor .... the decision about adding an outboard trolling motor will be made after we install the trim tabs and test them .... my hope is lowering them all the way down will produce sufficient resistance while trolling using the big motor to slow the boat down sufficiently .... if so, that would be wonderful ... if not, the next step will be to figure out the best way to install an E-TEC 15hp
Jim
mrdancer
Re: Trim Tab Use
Jim
If you do mostly open-water trolling, a drift sock could also be an option. A big one would slow you down sufficiently, would store easily onboard, and is relatively inexpensive.
QC
Re: Trim Tab Use
What's your speed with the big motor now? I have HUGE tabs, and they go waaaay down, and they drag me down from about 3 MPH to 2.5. I will verify that this weekend.
JEBar
Re: Trim Tab Use
the best I can tell with a boat speedometer that isn't very accurate and not having a GPS to verify the boat's speed, my best guess is a bit over 3 (less than 4) mph .... the Bennett M80 Sport Tabs I will be installing are 8-inch x 10-inch and designed for 17-foot to 20-foot boats ... our boat is a bit over 17' which I hope means they will be large enough to bring the boat's speed down to 1 - 1.5 mph .... that may be little more than wishful thinking, time will tell
Jim
QC
Re: Trim Tab Use
Not gonna happen. Sorry. You won't get that low.
JEBar
Re: Trim Tab Use
have done just that .... we purchased a drift sock and have given it a try several times .... while it does slow the boat down, all too often, it gets in my way while trying to bring in a fish .... one would think they deliberately wind my line around the drift sock rope ..:facepalm:.. really wish one would work and if the trim tabs don't slow the boat sufficiently, I may try it again .... that admiral would be much happier if I don't have to spend several thousand on a trolling motor ..:rolleyes:
Jim
Re: Trim Tab Use
if you want to get that low, start by having a smaller prop on your motor, or by pulling two drift socks. trim tabs will not slow you down to 1 - 1.5 mph unless you have a strong head wind.
JEBar
Re: Trim Tab Use
suggestion appreciated and I do fear you are correct about the trim tabs not slowing the boat down sufficiently but I have to give it a try .... for me, two drift socks aren't an attractive option, like I said above, when I've tried using one, they get in my way .... have considered going with a different prop .... in fact, discussed doing so with a local Evinrude dealer a few weeks ago .... if fishing was the only use for the boat, I might just give a new prop a try ..... however, a day at the lake for us usually includes several activities such as cruising, some skiing, along with the fishing .... from what I learned from the dealer, the impact on hole shot, speed, or general performance of the boat would be such that we would not want to change props .... in the end, adding a kicker motor will probably be the best option but with the expense of doing so being so high, we do want to exhaust cheaper alternatives first
Jim
Re: Trim Tab Use
I used to keep one prop for water sports, and one prop for cruising. would change it at the ramp or dock all the time. only changed it once by standing on the swim platform without getting wet. It could be an option.
JEBar
Re: Trim Tab Use
it could be .... I sure wish I had your experience and confidence in taking on a project like that
Jim
04fxdwgi
Re: Trim Tab Use
The tabs will slow you a slight bit, but not much. I find the most valuable part of having tabs and running at idle, is it stops the "Deep V wander" almost 100% at slow speed. You having an outboard, there is a device called a " Trol-A-Matic " or "Trolling Plate". Bolts to the cavitation plate of your lower unit and baffles the prop output at idle
http://www.google.com/#q=trolling+p...pw.r_qf.&fp=ab883cf15b672473&biw=1152&bih=663
It's available here at iBoats
http://www.iboats.com/Trol-A-Matic-...oogle+Shopping-_-Trolling Motors-_-T & L-_-NA
JEBar
Re: Trim Tab Use
suggestion appreciated .... I have looked into trolling plates .... last June while in South Dakota I spoke with a half dozen fellows who use them when trolling for walleye .... 3 liked them, 1 said his was OK but he was looking for other options, 2 said they didn't like them at all.... granted I talked with a very small sample but the highly mixed reviews left me looking in another direction .... that isn't to say we won't revisit trolling plates after we find out how the boat performs with the Bennett tabs
Jim
Re: Trim Tab Use
trolling plates are great if your an aluminum repair welder. most people with the manually latched plates forget they are down, throttle up, and snap off the trolling plate and most of the anti-cav plate. then they take them to the aluminum welder for repair.
the spring loaded ones work ok for a while.
JEBar
Re: Trim Tab Use
that is dead on with the negative comments I heard from the folks I talked with in South Dakota .... knowing me, operator error would no doubt happen
Jim
