trim tab ?
mauiboy
My ? is that I took my boat out last weekend and when I got up to plain and guned it it leaned to the starboard side as much as if it was going to roll over. I slowed it down and it got back to normal. Do I adujust the tirm tab to the direction of the lean or is it the other way.
sasto
Re: trim tab ?
The other way. If the port tab is down the boat will heal to the starboard. Depending on your switch or switches if you press upper right on the switch..... the port stern will rise which makes the starboard bow to lower
Those things can be dangerous in certain situations. I would recommend raising (switch aft) your tabs all the way starting out while learning till you get used to them.
I've been trying to teach the lady trim tabs for awhile without much success. It took me awhile with hours of trial and error. If there is a site that explains this manuver, cause I can't, let us know. I learned by feel without much instruction. I know what the boat likes in different situations and they are not all the same.
12vMan
Re: trim tab ?
I agree with Sasto if you're talking about stabilizer trim tabs, but it sounds like you're talking about the steering trim tab behind the prop, which should be turned (like a rudder) away from the lean. It's to offset the prop torque. There should be marks to set it at, and epending on your outdrive or lower unit, about 6 of them. I would start at 3 and go from there until you find the setting that keeps the boat level.
triumphrick
Re: trim tab ?
Most all trim tabs (Lenco, Bennett) have a dual switch that is marked "Bow Down"...
It is layed out so that the port or starboard switch lowers that particular side of the boat..
jerryjerry05
Re: trim tab ?
I think he might be talking about the steering fin.
If the boat pulls right turn it right.J
mauiboy
Re: trim tab ?
Thanks Jerry
your right on I was not sure what it as called I did pull it off when I changed the immpeller
I already moved it and will be taking her out this weekend
jerryjerry05
Re: trim tab ?
Center it.Then go for a ride.Make sure that the boat sets level whan setting still.A bent skeg will affect it a little.J
mauiboy
Re: trim tab ?
Thanks
It was centered when I took her out and thats when I noticed that she leaned to the right only when I gave it the gas and stayed that way till i let off onthe gas
mauiboy
Re: trim tab ?
Thanks Jerry
I move it to the right and she runs fine now
