trim tabs
imported_raymond2688
my trim tabs worked one minute then not.....I can not hear the motor run. They are original equiptment. I looked for a relay or fuse and could not find one. One tab i can move with force one I can not. It has the proper fluid.
any suggestions
Thanks
Re: trim tabs
any suggestions
Ayuh,....... Post this in the Boating or Boat Repair forums,.....
This is the Engines/ I/O forum.......
Btw,.... Get a Test Light,+ Follow the Power,... Or Lack of it......
Tabman
iboats.com Partner
Re: trim tabs
Raymond,
Trophy boats have used Bennett, Boat Leveler and Lenco Tabs over the years. Do you know what make they are and how old? Once I know I would be delighted to help any way I can.
Tom McGow
Bennett Marine
Re: trim tabs
Hi Tom,......... Long Time ,.. No See....
So how do you like the New forums here at iboats,..??.....
How's the rest of your Great Crew down there,..??...
Re: trim tabs
they are boat levler and the year of the boat is 1988. yesterday I heard the motor work and one side worked and the other did not. then just like that they quit agin.
Thanks
Re: trim tabs
If they Work,...... Then they Don't,......
You Probably got a Loose, or Corroded connection somewhere,......
So,........
"Get a Test Light,+ Follow the Power,... Or Lack of it......"
Re: trim tabs
Boat Leveler
checked all connections found some issues there and cleaned them.....pump runs one side works the other does not....the side that does not work the pump does run
Re: trim tabs
Crack the Oil Line,+ See if it's moving Oil,.....
If Not,..... Look to the Pump to see Why.....
Tabman
iboats.com Partner
Re: trim tabs
The Boat Leveler system is pretty easy to troubleshoot. From your description it sounds as if you might have a wiring or connection fault, most likely on the green or white wire since they control the valves. The valve for that side is not opening so even though the pump is running and making pressure the fluid is not able to get past the valve. Look over what I have put together for you, check all the connections for the red and white wires at the pump and swich, and try the troubleshooting.
Here is he wiring for Boat Leveler (as we last checked).
green=Port Valve
white= Starboard Valve
red=Motor Forward (pump pressure)
yellow= Motor Reverse (pump retract)
black on HPU=Ground
red on Helm=Control Positive
If I am correct on the wiring then here is how you can test it.
Remove the wires from the helm control and touch together as follows:
Operation=Reaction
(+), Red, Green=Port trim tab down
(+), Red, White=Starboard trim tab down
(+), Red, Green, White=both trim tabs down
(+), Yellow, Green=Port trim tab up
(+), Yellow, White=Starboard trim tab up
(+), Yellow, White, Green=both trim tabs up
If the trim tabs function correctly for each wire grouping then the switch is at fault. Also note that any loose or missing screws on the back of the switch (whether a wire is connected there or not) can cause the pump to malfunction.
This test may also be done right at the pump by using a hot lead. There is usually a connector to the wire harness within a foot or so of the pump. You want to check this connection for corrosion. You may wish to cut the connector off on the pump side and try the test on bare wires. Pay attention to the red wire since it is the one that should make the pump run forward (tabs down). If you test right at the pump and still no go, then the pump is at fault.
If you suspect corrosion on the wire connector near the pump, cut it out, test as above and reconnect using butt splices.
Here is a link to the Insta Trim / Boat Leveler website, http://www.insta-trim.com I could not find a troubleshooting guide there but confirmed the wiring colors so the troubleshooting should be good.
I hope this helps, let me know if you have any questions.
Tom McGow
Bennett Marine
f_inscreenname
Re: trim tabs
I second that but I would have replaced "Great Crew" with "the best damn company on the planet." :)
Re: trim tabs
well i found the source of the tabs working sometimes and not others. I never thought to look at the battery conection (that I would not have found with out tabman helping me on the wires). The wire was really really loose. now when operating the pump the side that does not work makes a different noise than the other side it is almost like a click when you go from up to down.....checked all wires no corosion.....hmmmmmm
