trim tabs
ma glastron
Got my new amita 3 prop today for my 3.0 mercruiser alpha 1. Went to put it on and it hits the trim tab. called solas up and he told me to cut the tab or buy a different style tab is this true?
Brewman61
Ensign
Re: trim tabs
Well, yes. You certainly can't leave it as is. So you have to either grind it enough for correct clearance from your prop, or put on a special tab that is made for this purpose. Your boat, your choice.
robjen1019
Re: trim tabs
He is right, just mark how much you need to remove and take it over to the grinder. Ive done a few myself.
Tail_Gunner
Re: trim tabs
http://www.iboats.com/Mercury-Marin...19838457--**********.736297373--view_id.39250
Theres the real thing you can see the fin is offset
tri-5-ron
Re: trim tabs
I'm not trying to ask a different question, or highjack the OP's thread, if that is the case, I will gladly start a different thread.
I too have replaced the prop today with a Solas prop, and am hitting the trim tab.
I just came back fron the parts store, where I had seen the offset tab, shown in the picture above.
What I had noticed about that trim tab, was that the radius of the casting, (where the tab/fin meets the base plate, was a MUCH larger radius, and resulted in a larger area of "blockage" in the thrust stream.
Also, the Trailing Edge, of that tab was huge.
It was litterally flat/squared off., about 1/2" to 3/4" wide !
Being 26 years in aircraft, having some knowledge of aerodynamics, and knowing that Hydrodynamics are roughly 8x viscus,(if I am recalling that correctly).
I opted to try trimming my existing trim tab first, as was previously suggested in this thread.
So with that, (and I hope this is still directly related to the OP's question),...
When trimming the tab, how much clearance should there be, between the trailing edge of the prop, and the leading edge of the trim tab ?
I have heard that it needs to have more clearance, than just a minimal trim "trim to clear", to reduce any cavatation, aft of the trim tab fin.
Tail_Gunner
Re: trim tabs
Thats a merc trim tab made for high rake props..Likem or not merc does have a handle on such things..
tri-5-ron
Re: trim tabs
Tailgunner,
Honestly, I wasn't trying to be a smart-***, or anything like that.
And I realize that merc has a much better handle on what they are doing than I do. I wasn't trying to star a arguement, and I hope it wasn't taken that way.
I apoligize if it came off that way.
so as far as the question reguarding trimming of the tab,
Is there a preferred amount of clearance between prop and tab?
Bifflefan
Re: trim tabs
I have that exact tab on mine and it works great. The extra thickness is just more anode in my opinion.
Tail_Gunner
Re: trim tabs
Tailgunner,
:) Hey calm down your observation was well said...I just pointed out it was a merc tab that does not take away anything away from your statement i was just pointing out something easy...Good to see the input though...Watch for 45 or hiswii to get on a tech roll..Now those guys get it going..;)
