trim tabs
shrowder1979
what is the best oil/fluid to use for trim tabs. can't see a manufacture name on the fluid tank. thanks
Re: trim tabs
Ayuh,... Generally speakin',.... ATF, or Hyd. Oil....
Tabman
iboats.com Partner
Re: trim tabs
Bennett, Boat Leveler and the old Teleflex and Trimmaster systems all use any type of Automatic Transmission Fluid.
We do not recommend Hydraulic Fluid as the system is designed for ATF.
The big racing type K-Planes use 10W-40.
With any system make sure that the Trim Tabs are in the fully retracted (up) position before checking or adding the fluid.
