trim tabs
whiteox3
has anyone made there own trim tabs? if so how. I would like to make a set the simpler the better some way to manual adjust the tabs no elect. are hyd any help please don
WillyBWright
Re: trim tabs
Flat bits of plastic, metal, or wood hinged with an aluminum or brass piano hinge adjusted with a turnbuckle connecting the tab to the transom a few inches above the hinge. Simple, cheap, and what you don't have laying around you can get at the hardware store. For better, you're better off buying some. ;)
Moody Blue
Re: trim tabs
In the process of doing the same thing. Do a search for POOR MANS TRIM TABS under boat topics and discusions. Some good feedback from other members there.<br />What boat/motor do you have ?
JB
Re: trim tabs
Boat topic.
rwidman
Re: trim tabs
Originally posted by whiteox3:<br /> has anyone made there own trim tabs? if so how. I would like to make a set the simpler the better some way to manual adjust the tabs no elect. are hyd any help please don
It's going to be difficult to adjust them while underway. :rolleyes: <br /><br />Being rather mechanically inclined, I'm sure I could design and construct something like this but I wouldn't, I would buy a set so I could enjoy my boat. If you have a smaller boat, check out Nauticus "Smart Tabs". Well under $200.00 and you have something worth putting on your boat.
Re: trim tabs
check out Nauticus "Smart Tabs". Well under $200.00 and you have something worth putting on your boat.<br />
Jdeagro
iboats.com Partner
Re: trim tabs
Whiteox3;<br /><br />I am assuming that you are located in Australia - If so we have two good deistributors there and you may also find them (Smart Tabs) at Whitworths.<br /><br />If you need more assitance contact us at www.NauticusInc.com or info@NauticusInc.com<br /><br />Do a search on this site under Smart Tabs for more info.
