TRIM/TILT ELECTRICAL CONVERSION
phx5kegsman
Hello, I have a 1978 Johnson 115hp Crossflow V4. It has a power trim/tilt with the older solenoid wiring setup. I also have a 1982 Evinrude 115hp Crossflow V4 that I have been using for parts. It has a power trim/tilt with the relay wiring setup. It works much better than the one on the Johnson. I want to swap them. How difficult would that be, and, what's involved in converting to the relay type. Thanks
Honorary Supreme Mariner
Install the trim / tilt ( 2 wire motor ) of the 82 on the 78.----Install the 82 electrical bits on the 78 as well.-----Trim and tilt switch on the 78 control can stay.
Chris1956
Changing over the motor and electrical stuff is pretty easy. That is routinely done, when buying a new PTT motor as they usually come in the two-wire version, with the relay kit and harness.
Of course, that presupposes the mechanical parts of the PTT on the older motor are still good. Also, PTT motors usually work or they don't. If the old PTT motor still works, but is slow, you might clean the electrical connections first and see i that fixes it.
I do not know if the mechanical parts of the PTT on the newer motor will fit on the older one. Racerone likely knows that answer.
phx5kegsman
The tilt trim on my boat motor (the 78) works, but it seems very slow to me. There is also a very small leak around one of the trim rods. The T/T unit on my parts motor (the 82) works well and is, somewhat, quicker. Also, the T/T on the 78 uses a, significant, amount of power. I'm not sure if it's normal, but when I use the T/T my voltmeter drops 3-4 volts.
Oh, and Happy New Year!
phx5kegsman
Chris1956, which connections should I clean? The ones in the solenoid box? Or, are there others?
Chris1956
Generally, the PTT motor wires should be cleaned, as well as the wires supplying power and ground to the solenoids. Don't forget to make sure the PTT motor black (ground) wire is well grounded.
phx5kegsman
I guess I forgot an important part of this conversion. I don't have the relay setup. Can I buy one? New? used? Or, can I just buy a couple relays and wire it up myself. If anyone has any info on this, I would really appreciate it.
Crosbyman
you can McGiver anything if it handles the load and poses no risks of overload
Chris1956
Gee, can't you swap the relays and wiring from the newer motor to the old one?
Making a new wiring harness is not difficult, but the swap would be better.
The early ones had the relay box mounted INSIDE the boat.----Like stayed there and did not come with the motor!
Crosbyman
ever notice car lights and radios while staring the car...same thing happens here
phx5kegsman
I found one on ebay. I've had this boat and motor almost 5years now and this group has helped me with every problem or question I have had, and done so without all of the B.S. that has become so common on the internet. THANK YOU!
