golbrick7
Thread starter- Joined
- Aug 17, 2010
- 42
Have a 1976 19' Hammond Ski Boat with a 165hp In-Line 6 Mercruiser Marine (4.1 Liter 250 CID) engine with a 1970-1977 Pre-Alpha Model 165 R Outdrive. It still has the original High Pressure/Low Volume Trim/Tilt Hydraulic pump. I believe the motor to the pump has gone bad. Will not raise or lower the outdrive. Just get a slight hum from the pump with engaging the buttons. Does the motor detach from the reservoir? If so, can the motor be purchased seperately? Any help concerning this issue would be appreciated.
