trim/tilt issue (s)
vincechig1975
I have replaced my trim cylinders, and the pump today and the new problems are cylinders go up very slow and the outdrive won't stay up. Frustrated beyond belief.
sounds like air in the system. If there is a procedure in the manual for purging the cylinder you will need to follow that. If there isn't then raise and lower the unit at least 5 times while checking the oil level as that should push the air out of the system.
aussieflash
If no leaks,do as glenn said.Up down a few times then check(while in up position) and top up fluid.Repeat till it wont take any more.
