Trim/tilt leaking down
wargle2
I have a 94, 90hp Mercury. I have replaced the trim/tilt motor/pump and bled the system. It trims up and down very good, but now won't hold position. It leaks from normal trim position to full down in about an hour. I've got to check the manual by-pass screw, but does anyone have another possible cause of leakdown if the by-pass valve checks good? Thanks.
