trim/tilt line leak repair help
foilled
As seen in photo below, how can i repair this leak i have on the tilt/trim line going into the cylinder? inside the blue circle is where it leaks. fluid comes out of the middle of the nut and outside of the tube. nut is pretty corroded in the cylinder and i cant seem to get it to budge with out stripping it. i also have next to no room to remove the other end of the hose, which is also very corroded and will probably strip trying to get that out aswell. what is the consequence of boating and just leaving the leak as in? any tips?
Ayuh,...... It'll be leakin' oil into the water, 'n the water will get into the system,.....
Eventually, you'll be replacin' the entire trim system hydraulics,......
foilled
is there any possible way to stop the leak without removing the line?
alldodge
Not likely, its under a lot of pressure (hydraulics)
alldodge
It looks like a loose fitting to me not a crack that needs to be welded. In most cases welding on aluminum is not a great fix
foilled
it is loose. i can move it around. do you think it is because of a worn o ring? also im just trying to think of an alternate solution as these nuts on the end of the tube is seriously corroded into the drive cylinder and even worse into the gimbal housing and im not feeling to confidante about getting them out.
alldodge
Most those fittings are a 37 or so degree fitting, so no O rings. The nut just needs to be tightened down so long as the faces of both the line and the fitting have no issues
foilled
alldodge
Appears so, you know more then I. This kind of lines the O ring does the sealing but nut has to be tight. Th
foilled
so ive managed to remove the nut on the cylinder side. the pipe wont actually come out nor will nut screw back in flush in an attempt to make the nut flush with the pipes rimed end, (it wasnt flush to begin with) any tips? im still leaning toward welding the outer circle to the center nut. i dont know how to make this hydraulic and water tight. i feel like water was getting in there already and its really corroded. i was prying on the pipe with the nut loose and it does not want to come out and im questioning a new one even being able to tighten in enough for a secure holding anyways. what would you do?
alldodge
I would remove the cylinder and see if the threads can be cleaned up, along with sealing surface. Welding isn't going to be able to fix it IMO. It might not even be fixable
foilled
[No message]
foilled
ive managed to remove the tube and the threads inside cylinder are basically flat the nut gets to a certain point and keeps spinning. i assume the hole is to big now so using the same thread size to retap wouldnt work. what should i do?
alldodge
The cylinder may be able to be repaired at a hydraulics repair shop, but my guess is it might be better to replace it
