how do you bleed a honda 50 hp hydraulic trim & tilt motor
R ROBERTandNADINE Recruit Joined May 31, 2011 Messages 1 May 31, 2011 #1 how do you bleed a honda 50 hp hydraulic trim & tilt motor
L levi_tsk Ensign Joined Dec 26, 2010 Messages 907 May 31, 2011 #2 Re: trim & tilt motor problem top it off with fluid and then run it up, down a few times,top it off again, up and down again check the fluid level and if its still good be good to go other wise repeat until it wont take any more fluid
