Trim & Tilt Problems - Help Please
mwbaughan
My old 200 v6 Mercury trim has been slowly going out for a year. I could tap on top of the motor with a lead weight and it would raise up. Recently I tapped on it and it sounds like the motor is spinning disengaged from the pump. I ordered a new motor but am worried that the problem may be in the pump. If I turn the release knob will I be able to lift the motor manually? If I could just get it raised and stationary in a more suitable trimmed up position I would be happy. Do you think the motor shaft was binding in the pump and tapping helped get it going and now the sahft has broken under excessive pressure?
cougar1985
Re: Trim & Tilt Problems - Help Please
i had a 60 hp mariner last year that i had to hit the trim motor with what ever to get to work at times.upon dissasemblly the motor was shot. replaced and worked like a champ.
