Trim tilt pump
wwilliamst
Hello i have a 1980s mercury thunderbolt 500 50hp outboard and it came with every thing but the the trim tilt pump and i cant find one any ware any one no if i can mod a newer pump or is there a electric conversion available sorry if i seem ignorant i am new to the boat seen thank you.
James R
Your information about the year is too vague. We need year and serial number. Can we assume at least that it is a 4 Cylinder. That in itself is also insufficient.
wwilliamst
Sorry about being so vague its a 3 cylinder and i did find some numbers that could be of interest but no sure here are some pics
James R
The number on the plate identifies the model.
Are there any other parts of the T/T assembly attached to the motor to show that it had a T/T. Not all motors had one. If it had a T/T the pump and solenoid assy would have been attached to the boat deck at the stern.
wwilliamst
James i cant find any other marking that would help i don't think but regard less do you think it can be moded if that is a word. From hydraulic to electric if i get the right actuators
mythx
Hi, I've got a thread going with a similar discussion for the '79 version of same engine. Going to keep an eye out for just such a kit.
It seems to me that you could find any 12v hydraulic pump with the right specs and adapt it to work with your cylinder. It would obviously take more work, but might yield quicker results if you can't find one.
Just a thought.
wwilliamst
Just a thought.
Thank you for your suggestion so you trim tilt cylinders have 2 hydraulic lines coming off them i am guessing supply and return 4 in total most pumps i see today just have 2 total
mythx
I ran across this video. Seems like a simple solution. I may end up trying it myself:
Back to your question, in order to power two cylinders, I would imagine some sort of splitter would do the job. You'd need 2 of course, one for supply, one for return.
Hope that helps.
merc850
The serial Nr. is at the top on that silver tag in pic 2. If your motor has the 4 hose cylinders you need a trim pump, all the fittings and the wiring harness - I wouldn't use just any hyd. pump the proper one has internal passages that allow the motor to kick up if you hit an underwater object.
